Also, change Mach3 to 100k on the port setup page.
Jay
So Mach 3 and the UC100 should both be 100k kernel speed. Correct?
Jay
I suspect that the kernel setting has nothing to do with the E-stop unless the UC100 is sending some kind of an error to Mach. I would look at the E-stop setting in Mach
I assume you are trying to turn on a known good, 60 Watt or so, 120V lamp with the SSRs. If they won't turn that on then I would say there is a major problem with the SSRs. The power supplies draw more than enough start up current to turn on the SSRs
The SSR's did not work with the lamp.
I'm powering up all three axis at the same time. But I do have good news. The two screws on the ends of the Z axis power supply/driver terminal block were loose. I turned them down about 4 turns to get them tight. After doing this the Z axis moves up and down and the UC100 error code doesn't come up. Evidently the terminal block wasn't making a good connection and tightening the screws cured it. We'll see.
That's crazy that all the SSR's don't work? What low volt DC source were you using to test, the 5v or 12v?
That great news! I'm glad you found it.
Jay
I agree, that is crazy. Just for a test, try to turn on the SSRs with a 9 or 12 volt battery. If they work, then I suspect that the DC coming from your wall wart is not filtered and needs a capacitor across the 5Volt terminals to take out the ripple.
I ran the lamp test using a 9 volt battery and the SSR turned on the light. The SSR's are good. So it looks like I need to get a 10mF capacitor for a filter.
Tom S
You might also confirm that the output of the wall warts is DC, I have seen some that are AC output. I normally have to use a magnifying glass to see the data plate on the wall wart, but your eyes might be better than mine.
Don't feel bad, you never let any magic smoke out did you? when the smoke escapes that's when you feel badMan, am I learning a lot about electricity and electronics! I just checked and found out the 12 volt transformer is AC output. That explains why it didn't turn on the SSR LED light. The transformer that is installed is 5VDC output and does power up the USB hub which feeds the SSR and the BoB. Still need the filter because the 9V battery powered up the SSR but the 5VDC transformer won't.
Tom S
