Getting ready to make Harold Hall's Grinding and Sharpening jig. I plan on this being a total Metric build with the exception of the flat table plate. I'm going to use 1/4" instead of 6mm. He uses 230M07 steel for everything round, which crosses to 12L15 on a couple of charts that I looked at. I have 12L14 which is slightly softer. I have used 12L14 which is a dream to work with but it doesn't wear good for me. I was looking at what the local supplier had and I started to look at 1144. Never used it before. Would this be a good selection to try? It is for pins (some threaded), feed screws, collars, collets, washers, etc. The application would be light duty, but a lot of use. I have on hand O1, 1018 & 12L14. Would like to try not heat treating or case hardening, but I'm looking for long life on the feed screws.
Thanks In Advance..... Chewy
