I do a little gunsmithing work, you've got a couple easy choices as a diy. A small piece tool steel can be easily heated with a torch and quenched then tempered in a normal toaster oven.
I love working with 17-4 for small parts I need to make that have to be hardened because a small kiln or furnace can heat to H900 or H925 easily with no drama and there's no scale formation or messy quenching. But you have to invest in a oven that can accurately hold a high temp for an hour.
If all you want to do is have the ability to heat small parts to high temps accurately when needed, you don't necessarily need something fancy...
There's a bunch of these on Amazon and ebay. You probably can't buy the parts to make it cheaper. It's a crucible instead of a door furnace but hey, you just need temp control and a powerful heater for tiny firing pins right?
Electric Smelting Furnace Small High-Temperature Castin Fluted Graphite Crucible
