Firing pin steel selection
Wednesday I'll be receiving five 1' pieces of 1/4" diameter 1144 steel, two 1' pieces of 3/8" diameter hardened multipurpose 4140 steel and one 1' piece of 1/2" diameter high strength 4140 steel.
I think that whatever is used it should be heat treated; 4140 HT is not all that hard, perhaps about 32 Rc, I'd be thinking of making the part out of 0-1 drill rod, it is a true tool steel, I think I'd harden and draw it to about 35 -40 Rc.
The advanced gunsmithing book posted in this section agrees with you that it should be hardened.
I can't wait to get the order of steel to do some more work on it.
I am working on restoring a particularly trashed FIE E15 revolver and one of the parts that I can't buy is the firing pin. I don't have a lathe but I made a functional replacement using a drill press and file out of 12L14 steel as a test. Now I feel confident I can make the part so I want to get a better steel for the purpose.
I ordered some 1144 rod from McMasters and I was wondering if it would be a good choice or is there something better available.
I am extremely limited in heat treating ability as all I have is propane and oxyacetylene torches and my wife's oven.
View attachment 484944View attachment 484945
I like O1 tool steel easy to machine and you can hardened the steel.
Dave
Best thing about 17-4 ph is the insanely simple heat treating schedule.
Buy your material in condition A
Then heat at temp in chart. Let air cool.
The number in each condition in the chart is the temp you hold it at.
For H900 the time is 1 hour. All other conditions the hold time is 4 hours.
With these low temps you don't have to worry about scaling of your part.
You can also buy the material pre hardened and machine with carbide.
So I just want to make sure I'm understanding this correctly. For the h900 condition you hold it at 900 degrees for 1 hour?
I don't honestly think I could achieve that with the equipment I have currently. I've been thinking about building a heat treatment oven though I don't think I'll be doing that too soon.
Yes. Hold at 900 F for one hour, ASSUMING you start with material in Condition A.
Or buy the prehardened stuff and machine away.
