- May 26, 2015
- 875
Finished everything up today save for waiting for for/rev gears to come. If there is anymore gear noise it will be the 80 tooth gear. It looks ok but won't know for sure until my parts come and I can test it.
Damn good reason to buy a surface grinder...or a pack of shimsMachining the thickness of a washer is no trivial task. You will probably be better off creating your own out of bar stock and parting it to the desired width.
Average cost of a cross-slide screw, for taper attachment, is around $250 and I don't think I'm going there. This has become the million dollar lathe that's only worth around $1800 on a good day. "BUT IT'S ALL MINE!" LoL (Investment $2200 and still counting!)
I think at this time I don't really need the use of the taper assembly. It would be nice to have it working but I can put it off for another day. I aligned the tailstock to the headstock and had to add about .005" shim between tailstock base and upper.I got a new cross slide screw (telescoping type) from ebay for ~$70. There are some over on PM that make them.
Maybe for an experienced machinist but not so much for me.It's not that difficult to single point your own LH 7/16-10 acme screw and attach it to an existing gear and shaft.
