You'll partially defeat the purpose of improving rigidity if you use t-nuts. I tried that approach first, and measurements were not gratifying. Here is what I ended up doing:
Not much choice on the 1127 as it has t-slots on top of cross slide. I guess one could drill and tap holes further inboard, but would be less effective and could only drill in about 1/2"
And they should. You 'could' make some longer/thicker t-nuts to give a bit more distribution to cutting forces. If you need more than that, maybe you need a larger lathe.
The t-slots on the 1127 should be more than substantial for the size of the lathe.
On my PM-1440GT the compound is held on with two small and fairly thin t-nuts. This is the weak link for rigidity. To make things worse, in the 30 degree position one of the t-nuts is within the access hole for the t-nuts.
Decided to replace the compound slide on my PM1127 with a solid tool post mount for an Aloris AXA QCTP. Has virtually eliminated chatter (especially when parting off) and has allowed me to set tool offsets for each tool. I’m planning on using miteebite fixture clamps or something similar to prevent the tool post from rotating View attachment 260150View attachment 260153
