- Oct 31, 2016
- 2,721
You guys are focusing on a non existent problem. Look at Bill Stupak's. He made the base thicker to gain the extra height he wanted. Making the post is simply turning a steel bar to the dimensions you want.
Step 1. Face the end of the bar.
Step 2. Drill the hole for the bolt that holds the base/post to the cross slide.
You may need a steady rest in steps 1 & 2. You may want to use a live center for steps 3, 4 & 5.
Step 3. First turn the bar to the OD of the base. Then measure off how thick you want the base to be and how long you want the post to be. Allow enough extra length to have a test piece for making the holders.
Step 4. Turn the post to the desired OD.
Step 5. Part off.
Your base/post is done. The bottom and the top of the base will be parallel and the post will be perpendicular to the post. The top of the post does not have be to absolutely parallel to the bottom of the base.
Making the base/post is the easy part in making a Norman QCTP. Making the tool holders is not hard. It was just time consuming for a newbie like me. You will use the 4 jaw to bore the hole for the holder. After you have the hole bored first saw a slot from the end off the holder to the hole. I used a hacksaw. Then drill and tap a hole for the bolt to clamp the holder to the post. Next drill and tap the hole for the height adjustment screw. Install the base/post on the cross slide and slip the holder onto the post. Adjust the height of the holder to the height needed to cut the slot for the tool bits or to drill a hole for boring bars. Drill and tap holes for set screws to hold the tool bits/boring bars. My first holder was for a boring bar. I now could use this tool holder to bore the holes in the rest of the tool holders.
To cut the slut for the tool bits adjust the height of the tool holder to the height needed for the slot. Put an end mill in the lathe chuck. A 3 jaw is fine because you will be milling the slot first to either the top or bottom of the slot. Then adjust the height of the tool holder to cut the slot to desired width.
The thread I posted above goes through this in more detail
Step 5. Part off.
