Probably my best bet.I've bought 3 really nice older live centers on ebay in the last couple of years. 2 were made in Japan and one in eastern europe. none were particularly expensive. all are very smooth turning. why not send it back for being rough turning? ebay is very good about returns.
That would be very nice. Too expensive for me, though.I have one of these.
https://www.mscdirect.com/product/details/00094623 I would love to get it serviced since it is worth so much.
if you buy a used one on ebay, ask the seller if it turns smoothly. if they respond yes, you have the record of that for a return.Probably my best bet.
I was typing a reply and saw the message was deleted. Think you had some valid points. Maybe the "accuracy" spec was shady, maybe not. What I received is not as pictured. The bearings really are poor, and the part has some seriously sharp edges, that I'd have to knock down before using. In essence, it's not quite fit for purpose.
Thanks for restoring your post. Was trying to remember the nomenclature for the kit. I'm going to check the taper tomorrow, and decide on the bearings. The bearings don't feel right, when it comes down to it.Bit of a "doh" moment. was editing, hit save without looking.
As regards the centre, if it is INAD or SNAD, return it. if it is defective, return it. If the seller refuses? open a case pshing for a return. If you do SEND IT TRACKED SIGNED FOR!
As I noted in my original message, I would look at a multi-tip live centre kit. At least with those, you can make a specific centre for your needs to suit the main unit.
This is the one I have, amongst other live centres. If I need/want to I can make a new tip to my own design / needs and use it with the main unit. It also helps that the bearings can be replaced relatively easily too.
Why not take it apart, clean it and relubricate it (it may be tricky to get apart, have to make some tooling etc) - then you’ll know how it works and know what you have. Was it a lot of money? Treat it as an educational opportunity.
I got a Rotor live center (Swiss made), MT5 - it was probably 30 years old, I don’t think it was ever used. It did not turn very smoothly, in spite of being a pretty high class piece of kit. It took some figuring on how to get it apart (when you get into the details there are a lot of different designs for rotating centers) - cleaned it, relubed, it turns very nice now (and I’m a little wiser for knowing how it works).
