- Oct 14, 2014
- 2,138
Galil will run any servo that takes a 0 - 10 volt signal.
I play fast and loose with the volt ratings. No way will the insulation break down if you go 20 volt higher. They just don't want the extreme RPM the motor would spin up to at the higher voltage. That never happens under servo control anyway. This may shock some of the more conservative in the crowd.
why this is late:
https://www.hobby-machinist.com/threads/message-awaiting-moderator-approval.72040/#post-604425
why this is late:
