- May 14, 2015
- 179
I had a dumb idea for the 1" 'live tool' sockets; rather than the simple solution of a pair of set screws on the underside, have a concave-wedge between each pair of tools pulled upward by a bolt through the tool plate. The added complexity seems to carry a number of advantages; I can see this scheme having more surface area/rigidity than set screws, it puts the fastener heads on the top side of the tool plate, and 4 fasteners would hold five tools.
Next dumb idea; form the obnoxiously-deep bores in the tool plate with sleeves inside an epoxy-sand casting. As large (8x12x3.5) as the block has become, a casting makes much more sense than machining. The density of holes may still be too great for that, however; I have no idea how brittle that material is. And of course the various component & tool mounting surfaces would also need to be metallic inserts set into the casting.
I also had a less-dumb fabrication question; whether anyone has tried one of these 'weldment frame' builds using brazing; braze is plenty strong, causes less warping/stress, can be applied in an oven (though with a ton of prep-work), and would seem to have damping benefits over welding.
