For Oscer, in the picture above, what looks like keyways in the gearbox is actually for the wicks. If you will notice, each one is right under a gits oiler, and there are 4 more on the other end.
David, that is a Smithy, Granite 12X24 and the table is both a milling table and the cross slide for the QC toolpost and is common to Smithy lathe/mill combos. It makes for a very stable and useful bed setups for line boring. I could have done both ends of the gearbox from one setup had it need it. That small silver cylinder in the tee slot in one of the pictures has a square hole thru it but also has internal threads with a set screw to advance the cutting tool when boring. It really worked out quite well.
Thanks Rick but I still have a ways to go on it. I'm waiting on a set of wicks for the spindle and I still have to press the bull gear off to remove the front bearing and clean the crud out from under it. Whoever worked on it before installed the bearing expanders incorrectly and had them pushing down on the bearings instead of pullin up on them. Then to loosen the bearings up so the spindle and bearings wouldn't overheat, they used a lot of shims under the bearing caps. Made quite a mess of them. Maybe I can get it sorted out when the wicks come in.
Hi Pat:
Thanks for taking the time to post the extra pictures of the line boring process. That is something I can make use of. I am really new to this stuff. Do you have a picture of the cutting bar? Looks like the cutter is set close to the right end of the bar, did you cut by moving the carriage left to right? Since you silver soldered the cutting tool into the bar, you made one cut only?
Thanks
Joe
No, the sleeve is silvered into the bar at about a 45 degree angle and the HSS bit is adjustable by way of a set screw in the end of the sleeve. The toolbit is locked into position by a grub screw that is perpendicular to the bar and intersects the sleeve and bit locking it when tightened.
I still have the bar and I will take a picture of it tomorrow and post it.
Here are some pictures I took of the boring bar this AM. The first picture is the bar and is 1" O1 tool steel and the toolbit is 1/4".
The second is the adjustment screw that extends the toolbit out of the bar.
The next picture is the first hole I tried to drill thru the bar at a 45 degree angle. It was a PITA for sure.
And the last picture is my Smithy that I did the boring on. It has been cleaned up, just not recently.
If I can help some others with any info, let me know.
Well thanks again Pat for taking the time to post more pictures. Thanks to you I learned how I can repair a 32 Ford gearbox that I though was junk. You and this site are just great. I do have another question. How much oversize did you make the bronze bushing and did you drive it in or freeze it or what? Also how do you determine bushing oversize for different diameters?
Joe
Joe, the bush is a press fit but I don't remember how much over the ID of the box I made the OD of the bush. I did drill the bush at the oiler so oil can get to the shaft.
