Mine is still in the process of being resurrected. 1966 MG Midget. Pulled it out of a field. Cost $200. Swapped in a Toyota 3TC with a 5 speed. Tight fit. The pan doesn't hang down below front cross member and the hood closes without hitting the engine. The header is a tight squeeze. No way the get equal length tubes. And I wanted to be able to R&R the starter without having to remove the header and the steering column. So the header goes over the steering column and then down. Currently working on replacing the wiring. I'll roll it out of the garage next week and take more pictures.
