- Oct 3, 2015
- 1,008
No doubt that chuck will be re-purposed for something, if nothing else a door stop.
All of the 6" chucks that I looked at had a mounting bolt hole pattern of 5.591", and the current back plate is only 5.620" in dia. This presents a dilemma, as I really do not want to have to turn and thread a raw casting. I did find one back plate for 1"-8 tpi, that I could just open up and re-thread for 1-9/16"-10 spindle, but I'd rather not go through the process of first making a spindle replication for a means of checking the threads.
After a few cups of coffee and much thought, it was then when I discovered an un-used chuck underneath my Jet lathe. I had totally forgot about this, as it was the original 3 jaw that came with my 1340, but I never mounted it because I installed a Bison 6 jaw adjust tru on that lathe right off the bat. This particular chuck has a D1-4 mount, so I tore the back off and realized that the studs screw into the back half of the chuck, not on a separate back.
After a gander at the insides, I realized that there was enough meat to remove the studs, and counter bore the back to inset the existing back plate.
I have turned many back plates, but I have never actually turned the back of a chuck. I figured the best way to accomplish this is by clamping the chuck itself to a trued bar between centers. The chuck has an 1-1/2" through hole, so I used an 1" round bar to clamp it to. This gave ample room to counterbore to 4.625" dia. and .250" deep.
I then turned the back plate to a snug fit, and proceeded to the mill and drilled and tapped 3 places 3/8-16 and countersunk the back plate for flat head screws.
Once I had it together, I mounted it on the spindle and checked for runout. I musta done something right....it was right on par with what one would expect from a 3 jaw chuck.
Sure , it's chinese, but what isn't nowadays. I tried to decipher the chinese chicken scratchin' and came up with 2 possible translations: #1. "manufactured by Lon Ding Dong, toolmaker to the royal emperor", or #2. "soy sauce"......
