Seneca Falls Star #30 lathe Resto-Mod
When we first got this machine moved into some good light and give it a good once over, I noticed some peculiarities that needed to be addressed. The first thing being the oddball taper in the tailstock quill. It was not quite right to be a #2 morse because the big end seated before the small end and left some wiggle. The small end of the socket was bigger than a #2, and to clean it up for a #2 was out of the question, so I bored it to a #3 on my lathe then finished up with a # 3 morse reamer. While I was at it, I set it up in the mill and cut graduations on the quill for quick reference.
It didn't come with a dial on the crank end like most lathes of the era, so while I was on a dial binge, I made one for it. The original retainer nut had to be turned down so a hollowed out dial would fit, and it is large enough to read fairly easy.
Another thing missing was a graduated dial on the compound. After I pulled the screw, it was found to be a 14 tpi, which comes out to .0714285" per revolution. So when I made the dial, I just made 72 lines and called it close enough.
Although it was optional at the time, there was no thread dial, or a provision for mounting one. Once I figured out the gear size, I made the unit using a couple of 1" pipe caps for the flares top and bottom, and a scrap piece of barrel for the middle and brazed them together. I added the angle iron bracket and tipped it slightly so the gear meshed with the leadscrew helix.
View attachment 263594View attachment 263595
It was cramped fit around the half nut lever, so a knob was added to the lever to better access.
WOW! I'm impressed. What a project! I once built an airplane which I flew for twenty years. It was quite a project, so I can appreciate excellent work. Now I have a goal for my lathe, but I don't think I've got enough years left to do it.
Cheers, Chuck
