Re: Rhodes Shaper
Thanks Bernie!
Though my scraping is still pretty bad, I figured a flat surface scrape on the graduated vice base was something I could reasonably handle.
Rather than indicate it on the lathe to true the first surface I decided to see how much effort it would take to just scrape that one flat.
Got it within a couple tenths but that was just too much effort. Had tried doing much of it with my flat pull scraper.
That scraper is is generation one and I'm thinking on how I want to make gen II as it's not very good.
With one side now flat I put it on the rock and the indicator said the second side was 0.0027" out.
Put it on the lathe and faced it. Still had several tenths to clean up.
There's a few small spots where I gouged too deep and they indicate 2 to 2.5 tenths but they are very small and not by the bolt holes so I'm discounting them.
0.0001 was the final reading on this 6" circle.
That was a lot of work and I'll use the machine tools to do most of it next time as well as make better use of the scrapers.
Checked the bottom side of the vice. The top isn't finished but its close enough that the vice didn't rock for this check
1.2 mills to true it up.
Think I'll take a brake from scraping and work on other things for a bit.
