- Feb 2, 2013
- 4,078
i tried the low temp aluminum brazing rod for the first time, i'll give it a THUMBS UP !
i made a repair to an aluminum motorcycle intake manifold that was modified by a moron
i had to close up an enlarged bolt hole, then re-drill the mounting tab.
it worked very well once i got the hang of the working temperature,
expect a learning curve- practice on similar scrap material first
the melt temperature is around 730°F
the aluminum must be clean- use stainless a steel brush thoroughly
they claim 71,000 PSI deposits- it is harder than cast aluminum- the deposits drill well
