A proper scraping job on a knee mill is an extremely labor intensive job, and takes meticulous planning, and excellent metrology equipment.. If you don't have proper datum points established, you can spend many hours of your time making your mill much, much worse than it originally was. You can scrape in your X axis perfectly to itself, and have it out of square with Z axis, same with the Y. I cringe when I read about a new machine owner deciding he needs to scrape his older mill or lathe, and has taken NO classes on the subject.
