- Aug 19, 2023
- 1,137
Another common way to secure them where a nut can’t be used ( like on a pulley or gear hub) is to use 2 sort set screws. The first one locks the pulley to the shaft. The second one is screwed tight against the first locking it in place.
I know what you mean.. I think...
I have seen and removed pulleys where a grub screw is inserted and locks down the pulley to the shaft, then a second one is inserted above, in the same bore and tightened down to lock the first grub-screw in place.
