- Jul 30, 2012
- 505
This may be crazy, but would a sanding drum work? Homemade mandrel for the sandpaper and threaded rod chucked in the drill. Course grit should remove the .010" guesstimated above.
Since the pin will not be 'turning' at any RPM to mention, binding will be the only concern. And it's not a super high precision part. You can sneak up on the fit.
