- Dec 26, 2016
- 2,113
Hi and thank you for your post, I went with a smps power supply because when I started to work on this project, using it seemed less complicated to work with, and was readily available ,I also just couldn't get my hands on a microwave transformer and was more focused on making the project quicklyIn closing, having looked at the LRS page, it appears that it is used for soldering metal pieces together
rather than for electronic work. Maybe it has some useful application not particularly obvious to me.
I'm certainly not trying to pick apart your project but rather trying to understand it's usefulness.
but after looking into it more I noticed every LRS units (for industrial use or hobby), is low tech and comes with a huge AC transformer, now that I understand a bit more I know I have to go find myself a decent size transformer, there are a few how to blogs/videos on how to take them apart and rewire them.
The reason for my interest in low resistance soldering is, I usually work with thin sheets of copper and brass for my projects and I often solder parts for these projects, the problem with conventional soldering is heat. when there are a few joints that need to be soldered, by the time I solder one, the heat from the process tends to loosen up the previous soldered joints ( which are) in close proximity, low resistance soldering creates much less heat and the heat it creates is more localized / usually does not affect other soldered joints, that's my reasoning for wanting to make my own LRS , the ones available commercially are in $500-$700 range but going low tech , I can probably do it for $100.
Thanks again for your post , please keep it coming.
