- Dec 26, 2016
- 2,113
I am in the process of building a Low Resistance Soldering(LRS) , all that's needed initially is a microwave transformer, an old soldering iron(to be dismantled and only use the gun's outer shell), some wire, foot pedal, anyhow, I skipped the microwave transformer all together and decided to go with a ready made 110V 50 Amp power supply.
The LRS assembly went very smoothly but the power supply has built-in fan that is constantly on and running when the unit is plugged in and that's what concerns me. the problem is: as soon as I start to solder, the fan stops running although the unit still continues to supply power ( I can still melt the lead and solder), I was wondering if this is supposed to happen ?
I read a lot of reviews on this power supply and it seems the fan is supposed to be always on.
On the power supply body there's a notice that goes like this:
This power supply has a built-in fan on/off control circuit.
Fan automatically works according to working temperature.
If that's the case then why it's running prior to soldering but it stops when under load? Bear in mind I am a novice working with electricity so it might be my ignorance that's getting the better of me but it makes more sense if the fan keeps on running especially when I'm using all the amperage the unit can produce , I never used the unit more that 30 seconds, maybe the fan sensor needs time to detect the excess heat and will eventually starts "Automatically"
So do you pros think something is wrong with the power supply or the fan sensor? do I need a bigger/better unit with higher output?
I can still return this unit if I have to, this is actually my second power supply,, the first one was a 30amp and much cheaper($31 CDN) this one I really like to keep because it feels more refined or should I say "robust" and twice the price of the older one.
I would appreciate your thoughts and welcome all your comments.
