You really want to test every scale that comes through and then deal with the rejects? My experience is shipping from China is cheap, the return trip is expensive and may be quite delayed, so probably more than the cost of the tape you are returning. Then you need to deal with inventory and shipping, just not enough margin there for the effort. What I usually see is many people end up buying the cheapest DRO/scales they can find, most will not even care about the tape error let alone have 18" of travel on mini this and mini that. Alternative is to just setup a pass through link to Ditron/AliExpress with the higher resolution specifications outlined, and then they can directly order "the high precision model" and see if Ditron can add it to the pull down menu or have it tied to your link.
Ditron is China's leading manufacturer of DRO system,magnetic dro scales ,we can provide you with high quality magnetic scales.
www.ditron-dro.com
Ditron's price for an 18" 1um magnetic scale is around $176, add another $30-50 to that for high precision and you are priced out of the market, and that is with you having to deal with all the headaches and probably a loss revenue wise. It is less expensive to order it the Machine DRO, 1 micron head is an extra $20, you deduct VAT and shipping was not too expensive in the past. If you want high linear resolution, glass scales are much cheaper and for the most part pretty decent. I know at least a dozen people that have ordered complete DRO kits with magnetic scales for Machine DRO, not aware of any of them complaining about the scale accuracies (both 1 and 5um).
The M-DRO EHC Series compact linear magnetic encoder with 465mm (18 5/16 inch) reading length tape. 5 Micron (0.005mm) resolution. Featuring the DRO-MG-EH-05C Compact reading head, which offers a smaller reading head size compared with our standard EH series head. The dimensions of the compact...
www.machine-dro.co.uk
Your review of the different scales on your website is very helpful, would be a real PTA to have a high expense item when there is little to no profit margin. People can choose based on the information you have provided. Unless you plan to go into full blown production and have more of a margin, I just can't see trying to add this to your pile of thing to do.... Just an opinion.
Adding a decent electronic edge finder that works with your DRO kit, may be worthwhile and/ot a link to those that you recommend.
