Thank you for the questions, sorry that it took me so long to reply!
I am 6'1". The wooden cribbing is indeed for my back; hunching over a machine gets at me quick. Wood would eventually warp, twist, crack - but it won't really squish under the few hundred pounds that these machines weigh. Yes, it will effect level and twist, and it most assuredly does not help with vibration
I decided I'd be ok with it for now because I got tired of trying to level and stabilize everything, and I wanted to make things - they might have a taper, but so far I've not been doing long skinny, just short- fat.
The better solution would be some big-ole' cast-concrete footers with a fantastic finish and J-bolts inset. God willing, when I build my shop that will be the case - dead nuts level and 8 - 12" thick poured just for these ladies...
There is a 6" bench grinder by the tailstock, and it is ideal to suck the grit out of the air, as well as protect the ways. The bench grinder is, however, the least of the concerns - now that I've got this thing:
I have a "cyclone separator" that I made with an old vacuum, a road-cone, and a 5 gallon bucket. I've not yet made a suck-funnel for the grinder, but someday - plus a coolant shroud.
My Lab is about 13x20, and I am somewhat adept at cramming things into places where they might not otherwise go - but we hobbyists make due with tiny places yes?
My metroloscopy station (granite, gauges, and an optical comparator - hence the "-oscopy" part of the "metrology") has got a bed-sheet on it
I'd suggest, if you're wanting, get some graph paper and make a scale of your shop - then cut out bits to scale for your machines: this includes the full working envelope including table travel, and swarf-shoot-off - then you can arrange your shop like a board-game. I spent a few hours with a tape measure finding the way to fit the machines with the walk-ways. Because they are heavy, one is loath to move them more than fifteen times or so...
