I would prefer a left handed drill bit. Since you have damaged one side, it may not come out that way, so back it out from the other direction.Go to your Dremel kit, and find a 1.5 mm diamond abrasive-doped bit. Plunge it (using your mill or drill press) into the screw to cut away the broken face, leaving a flat surface. Then drill through with a carbide drill bit. Then use whatever fits the hole as an arbor/extractor, and back out the shell. Good luck, that's a toughie. If it was more proud of the insert seat, I'd zap a nut on the stub with the welder and go from there, but that might be too deep for its size to do that.
Yes: this is how I was able to remove a 2mm setscrew from an Aluminum knob (very carefully - didn’t touch the threads in the knob so was able to reuse).Go to your Dremel kit, and find a 1.5 mm diamond abrasive-doped bit. Plunge it (using your mill or drill press) into the screw to cut away the broken face, leaving a flat surface. Then drill through with a carbide drill bit. Then use whatever fits the hole as an arbor/extractor, and back out the shell. Good luck, that's a toughie. If it was more proud of the insert seat, I'd zap a nut on the stub with the welder and go from there, but that might be too deep for its size to do that.
I like that pipe column in the corner with adjustable height swing out work bench!Working on a new robot cart, got some kiddos welding in there too!
Sent from my SM-S911U using Tapatalk
@savarin, Thanks a lot - really! - for posting a link to the description of the construction of this simple DIY EDM.Make one of these, very simple to make and use.
Darn near killed myself after I chose to do the demo on our kitchen tile counters. What a mess!Damn . Such a small bathroom to gut . Never knew how much weight there was in the tiles on the walls , tiles on the floors , the concrete on the floors , the frikkin metal mesh in the concrete below the tiles , the cast iron tub , the toilet , sheet rock on the walls , etc etc etc . I wish I was 20 YO again . Been a long day but knocking it out .
