- Mar 22, 2022
- 390
Remembered to go learn the difference. "BPPV and Meniere's: Two Usual Causes of Vertigoyea, no, this is the crystals. It's being affected by my right inner ear. Sucks that I can't clear this one. Not sure why. Went to the Dr today, and they tested me and confirmed it's BPV.
Interesting. Did the piece stay flat once you removed it from the rest of the blade?I went at an old blade for a splitter and mount for a blade guard with a cut off disc
Sure, something more to learn. I didn't throw it on the surface plate, but on the saw table, that surprisingly is pretty flat, it doesn't rock. So probably good enough for the task. After using the disc cutter, I suspect the hardness is less toward the center of the blade. FWIW it measured out @ ~ .060"Interesting. Did the piece stay flat once you removed it from the rest of the blade?
I was wondering if there would be tensions that might cause it to warp in weird ways once it was cut. I know really big mill blades are not “flat” at zero rpm’s, they need the spinning of the arbour to flatten them out. Obviously this is smaller, but I still wondered about it.
