- Nov 24, 2014
- 3,704
You need to add some back rake to the tap . Just a little. You can grind it, sand it. 10 thou for cutting plastic should be enough.
so you are saying off center, toward the back end of where the rake would be
I think you are using the wrong terminology. I think the correct terminology is CLEARANCE, back clearance or radial clearance.
Rake is the angle of the cutting plane relative to the center axis of the tap. The slots that @WobblyHand cut provide quite a bit of positive rake.
Back clearance, or radial clearance, is created by the thread form of the tap decreasing in radius behind the cutting edge. The lathe cut, single pointed thread form creates essentially zero variation in thread form radius. The purpose of back clearance in a tap is to eliminate unnecessary friction and resultant heat. Friction and heat are not significant factors in WH's project.
