Not much really. Made a pseudo tap for 3d printed threads. Couldn't see spending the money (and waiting) for a 3/4-20 tap. Single pointed the threads for 1" thread length, then ran a 3/16" mill to form the grooves. Didn't have a ball mill the right size, but still wanted to get it all done. Was thinking of using a 5/16 carbide router bit and thought better of it. This was simpler. Not pretty, but functional. It's not a forever tap, if you know what I mean! Took a bit of work to clean things up again after that slot made a mess. I ended up putting the piece back on the lathe and re-synching the thread to "chase" it. I then used a stone to clear out the crud at the thread ends. I didn't have the right kind of steel, but for cutting/chasing threads in PETG, I figure 12L14 will be more than ok.
My printed threads were only a little bit small. Here's the fuzz my tap cut. The black stuff on the edges is the PETG. The tap was clean of all chips and debris before tapping. The tap threaded in only using my hands, no wrenches. That was going to be plan B, install a handle, or cut a hex. Plan B wasn't needed.
FWIW, the corresponding item was 3/4-20 printed at 0.2mm layer height, with a 0.4mm nozzle. Some people have problems with printing threads. Mine weren't that far off, as seen by the minimal amount of swarf generated.
I could see doing this again for some un-obtainium thread, in a better material, it wasn't that tough to do. Might even consider hardening the result (using O1 perhaps?). Maybe I could use a slitting saw for the slot?
