Headlights are polycarbonate now, IIRC. I don't think that acetone on polycarbonate is good.As a product available in the EU, acetone makes the most sense. It seems like a safe enough way to do it considering the hazards using hot acetone entails. I'd certainly give it a shot. Frosty headlights on your baby can be a real tear jerker.
These plastics are softened by acetone:Headlights are polycarbonate now, IIRC. I don't think that acetone on polycarbonate is good.
It must be something that's in a volatile solvent, and leaves the hot bottle with the solvent. And stays behind after the solvent 'goes away'. But guessing that acetone might not be it because acetone on polycarbonate is bad.
Edit. Some references are acetone. Hmmm. Usually that's bad with polycarbonate. I'm starting to smell snakeoil salesman stuff here...
Anyone have an MSDS for the stuff?
I would be very careful using Acetone on plastic or any surfaces. Over the years I have totally ruined numerous plastic items by just exposing them to drops of acetone. It is pretty reactive stuff. Test carefully prior to using. Reaction times vary greatly.As a product available in the EU, acetone makes the most sense. It seems like a safe enough way to do it considering the hazards using hot acetone entails. I'd certainly give it a shot. Frosty headlights on your baby can be a real tear jerker.
so you are not putting it on with a brush, you are using the vapor to re-melt the surface of the polycarbonate and smooth it over.Headlights are polycarbonate now, IIRC. I don't think that acetone on polycarbonate is good.
From what I've read, acetone doesn't melt polycarbonate.so you are not putting it on with a brush, you are using the vapor to re-melt the surface of the polycarbonate and smooth it over.
