was the 18 degrees to avoid the shaft of the knob?
Yes, otherwise the boring bar will hit the shaft. When I make the 2 for the Jeep, I will turn the shaft smaller, likely the size that I will bore the hole to tap for the gear shifter.was the 18 degrees to avoid the shaft of the knob?
Impressive. I have done it the old fashion way… wet sanding up to 3,000 grit then using plastic polish compound. Last step is coating so the work last… or using a clear film resistant to UV…. But that is a lot of work.Few months ago i've seen couple of videos on vapor polishing and polymerization on headlights. Almost all my car have plastic headlights and polishing, clear coating them is a real pain when having more than 20 vehicles. The process i mentioned earlier seems to be very easy and also should last for years. I started asking around no one even heard of it. So i opened aliexpress and looked at kits for polymerization, many of the sellers did not want to ship to my country but i managed to find one that sent me the heated cup and others that sent the fluid, i had an 12v adapter with that i completed the set. I took a very damaged headlight from one of the octavia's sand it with p600 then with p800 and gave it a pass with this vapor process, it magically turned clear. I'll leave this headlight out side to see how long it will last, but for easy use its very easy and much clearer then some of the polishing processes.
View attachment 459792View attachment 459793View attachment 459794
A buddy has a body shop. He just sands them down with 400Gr, and does an automotive clear coat over them. The automotive clear floods the sanding scratches and also has UV blockers. I think you can get automotive clear in a rattle can to do this 'in car' with some masking at home. Doing one sanding with 400 has got to be way faster than going to 3000!Impressive. I have done it the old fashion way… wet sanding up to 3,000 grit then using plastic polish compound. Last step is coating so the work last… or using a clear film resistant to UV…. But that is a lot of work.
