- Jan 4, 2021
- 3,303
Here is a discussion of common problems that have been identified with the older (Aluminum) iGaging Scales either when used with TouchDRO or with the factory readouts. When I first added my TouchDRO to my iGaging Absolute SS scales, I communicated with @ycroosh and he recommended not doing anything special unless I already had issues with the factory readouts. The scales on my Mini-Mill haven’t had any issues.Read up on noise problems with that aluminum scale era cheap magnetic digital scale. Plenty of people talk about fixes that have worked for them. Isolating them from the machines seems to work for me. If it goes back to glitchyness, it's going to get replaced. I have tried what I am willing to do to fix it. Like I said though, this scales twin has worked all over the shop in different mounts made of that grey plastic. In fact, I carved those two pictured mounts out of a block used to adapt a Z axis dro when I first got the 12x36 going. The slot in one block hides the remnants of a two hole pattern. The other one still has two threaded holes in it. I did mention frugal didn't I?
I do recall reading several reports of the Aluminum scales having issues with the stamped factory mounts, and that the problems went away when machined Aluminum brackets were used. @LEEQ ’s fix may have also worked with Aluminum brackets instead of insulating ones, but the important thing is that they now work.
