Today i made a bit of an improvement in my tool storage in the big garage. In this garage i mainly do mechanical repairs and welding and my tools are strong about everywhere. If i put them on my work bench they take up the entire bench, so i found me a corner post in the middle of the work space. Started by mounting two metal strips, welding couple supports and mounting my small bench grinder. Then i moved to mounting my black box that contains my allen, torx and triple square bits. I use pop rivets and reinforced the hinges, the bottom will rest on the grinder and when i want to use the grander i simply close the black box. Above the black box i place the orange box that contains my impact sockets they are heavy so i also used bolts thru the metal strip into concrete. Above it i made a small pedestal and mount the blue box and above it i bolted on couple of chip boards on which i hung up couple more tools. Everything is with in reach and everything can by easily closed up when painting not to get overspray on it.
Not a lot of time after work this week. Second coat of paint done on the mount
Out of the evaporust and pending paint removal for the leveling mounts and cabinet hinges
Cabinet scrubbing is finished
Some progress is better than no progress
