- Dec 20, 2021
- 1,066
Clarification: I'm a BIG TIME solder geek. Don't ask...well the goal was to see if what I had would work. I didn't consider these electronic solders. What would they be used for? not rosin cored? I don't think the flux is acid.. I used to think that. But something I read at Harris kind of changed that for me a while back. I don't remember what it was.
Zinc chloride is common acid flux.
There are hundreds of solder alloys. There are some that are more common than most. The solder metal can be used for more than just one type of thing (HVAC, Mechanical, Electronics, etc.). The flux used will typically vary with each application. Rosin based Fluxes are typically used for electronics ( there are different varieties of flux in this class also). Acid based fluxes are more often used for HVAC and mechanical purposes.
Most people think of electronics solder as the old school leaded solder, typically 63Pb37Sn, 60Pb40sn, etc. Those melted at around 183C, but are pretty much obsolete (unless you are military/aerospace, etc.). These were replaced with lead free solders that melt ~220C. Typically silver bearing solders Sn96Ag4, Sn96.3Ag3.7, and SAC 305 (Sn96.5Ag3Cu0.5). SAC305 is very common now.
In your case, my guess is this kit is for HVAC or similar. HVAC typically being copper to copper it would work well. It would also work well for repairing mechanical items, or even jewelry. The exact same alloy is available in rosin cored wire for electronics. You could use yours for electronics with a different flux.
Anyway, keep in mind that if the cutting tool gets hot you'll loose strength. If you start smoking cutting oil (150C???), you're probably close to popping the solder off. If that happens, something like the Harris Safety Silv 45 would be good.
FYI, I've used Harris0, phos-copper in a pinch. Not ideal but seems to work. Lots cheaper than the 45% silver brazing material!
