Ahhh. Took a while to figure out. The S-167-2 is the heat number. It looks like the Stay Brite alloy is Sn96Ag4. Standard lead free tin-silver almost eutectic mix (Full eutectic mix is more rare - Sn96.3Ag3.7). Also very similar to Sn95Ag5, which would be just slightly tougher (95-5 is ~10000 psi, vs 96-4 at ~6000psi or similar IIRC).
These are electronics solders, not the high temp brazing silver solders. They melt at 221C. No need to heat anything up red to use these. For steel/carbide use an acid flux (which is what I think the bottle is...).
The 96-4 is nearly eutectic and will solidify at the same temp, so you can play with it until it almost freezes up. Others have a 'mushy' stage as they cool, and you don't want to move when it starts cooling.
If you do more of this, you might want to look into the silver brazing type solders. You can do some of these with just a propane torch. The carbide and mild steel can take the red heat.
