POTD was a little proactive tool work for our Case 580 backhoe. I've vowed to do a better job of preventative maintenance on the Case. Changing fuel filters requires shutting off the petcock valve on the bottom of the tank. It's a royal PITA to get to; poor hand clearance around a hydraulic and other lines from the topside, or a real high reach if coming at it from below ground. Plus, it's not the easiest screw to turn and is tough on the fingers. So, POTD to make an adapter to get at it with a ratchet.
The petcock "wingnut" is about 1 1/4" long with a center area ~0.450" in diameter and wings ~0.400" wide. I figured on a trough in the Delrin about 1/4" deep would capture the valve.
I chucked up piece of 1 1/4" Delrin, faced, and drilled a 25/64" pilot hole for a 3/8" broach. Then drilled a 29/64" hole (little bigger than 0.450") about 1/8" deep. Bored the hole to 0.460" at 0.25" deep and parted off.
Drilling the 25/64" hole for the 3/8" square broach; plan to dump a 3/8" extension in for tightening/loosening the valve
Shallow 29/64" hole to clear the center of the petcock valve
Boring the clearance hole for the center of the petcock
Parted off
Chucked the parted off piece back in the lathe and broached it there. I'd usually use my hydraulic press, but the Delrin is soft and it's a lot easier to advance a 10" long broach on the lathe than having to fiddle with the hydraulic press and its 5" of travel.
Broached the 3/8" square hole on the lathe. Goes a lot quicker than using my 20-ton press with 5" of travel (have to adjust the table)
Then to the Bridgeport to cut a 0.400" wide dado for the petcock wings. Quick threw it on the Case, looks like it'll work out great!
I'll crawl under the backhoe with a cordless driver and extension to open/close the petcock.
Thanks for looking, Bruce
