- Sep 28, 2013
- 4,413
Any time I need to cut a plug of foam out I find a piece of thin wall tubing (the thinner the better) the right diameter and sharpen it razor sharp and and twist it through gently letting it slice with minimal compression. I've also made a mandrel for said tubing a couple times and used it with a drill for deeper or repetitive cuts.Next up is to make some kind of “cutter” to punch out a nice round piece of ME that will fit the holder without having the “scrunch“ the ME up to fit the holder. ME doesn’t cut well with scissors….
What a beautiful finish!Well I haven't power washed my car yet, but I did finish my collet chuckView attachment 448606View attachment 448607View attachment 448608
Was thinking something similar, just need to find the right id thin wall…Any time I need to cut a plug of foam out I find a piece of thin wall tubing (the thinner the better) the right diameter and sharpen it razor sharp and and twist it through gently letting it slice with minimal compression. I've also made a mandrel for said tubing a couple times and used it with a drill for deeper or repetitive cuts.
What's the inner diameter?Nice simple afternoon project:
its just a simple holder for a piece of MrClean Magic Eraser.
The ME is used to clean the stylus after playing a record.
Its hard to beat a ME for cleaning residue off the stylus. You just position it under the stylus and “dunk it” several times. The ME scrapes the vinyl residue off (and other nastiness that collects on the stylus) and gives you a fresh clean stylus for the next lp.
I’ve seen it work. I use a 100x magnifier and the stylus is pretty gross after playing a couple records that haven’t been ultrasonic cleaned. Couple dips and the stylus is factory fresh again. Simple, but effective.
I wanted a holder of some sort to keep dust off the ME, but more about having a nice convenient way to position the ME under the stylus. Most people stick the ME to a toothpick or similar, but that just seemed too “bush league” for me and this was a nice, simple project on a rainy afternoon.
Thanks! No idea what that metal was, but push it hard and it would make blue spirals and a beautiful finish. I guess in the metal karma world that balances out the misery I had with the last couple of pieces of mystery metalWhat a beautiful finish!
So, is that one of those cheap import chucks? Looks pretty nice. Now that my lathe is done, I keep thinking one of those would be a good idea. That, and about another half dozen other things for that lathe...Well I haven't power washed my car yet, but I did finish my collet chuck
Do you guys get a lot of rust down there?I hear you on the "working on old neglected cars" front. The joys of removing old stuck fasteners, or not in the case of the rear brake cylinder bleed nipples..
