- Dec 20, 2021
- 1,066
The advertisement was 50mW, measured 112. The 405nm was 205mW, advertised as 200.112mW of green is hazardous to the eye, never mind the IR. Why did you choose such a high powered device, it wasn't for this use was it? I mean it is pretty neat and all, but it's not needed for using on an optical flat, is it? Very nice set up, though.
The IR leakage should be filtered out. But I don't trust the Chinese, so this will get an IR filter before the diffuser for the final go.
Yes, I did choose it for this application. You have to remember 100mW in a pinpoint is a lot. But as soon as you run a diffuser, and spread it in every direction it's not much at all. Actually it's not really enough light for this application, spread over a spherical area. But it was the absolute cheapest monochromatic light source that could be made. (Even low pressure sodium bulbs are going for over $100 now!)
For comparison, the light cast from that green pingpong ball is drowned out by 400 lux of white room lighting when the ball is 6" from a sheet of paper. It's enough to see interference patterns on the flats, but room lighting needs to be off.
In general, you are correct, you need to be careful with lasers. And unless you know what you are doing, just don't. Especially with unknown import stuff showing up on ebay.
Actually, I brought a bunch of laser pointers to the power meter when I tested these. The little chinese pointers in blue and green you get for $3 tested at 45mW and 40mW ea! They're supposed to be under 5mW! A red presentation pointer was about 1mW.
I do have some 2000mW and 7000mW 455nm blues, now those are scary dangerous.
