Was printing off a collet rack for my er32 spring collets. Somehow, pressure built up in the hit end head and it blew out the threads holding the heat break to the heater block. Melted abs went absolutely everywhere!
With the threads gone, I needed a new heater block. I run an e3d volcano hot end, so it was going to take several days to a week to get replacements.
So down to my new mill and start taking stock of what I have to work with. I’ve literally had the lathe 3 days now, so nearly no tooling for it. So I took the drill press vice and bolted it to the table on the mill. I only have a couple end mills and nothing to hold them in. So I had to use the drill chuck to hold the cutters. Not ideal for many reasons, but I kept the cuts very light and only shaved half width at a time.
To sum up, i got it done after a couple hours fiddling around and the 3d printer is up and running again. Should be able to pull the collet rack off the print bed within the hour.
So I’m not sure if my POTD is the 3d printed collet rack or the heater block I had to make for the printer on the mill so I could make the rack for the mill….
