- Nov 26, 2015
- 5,134
Well one step forward and one step back. I got the big Jet lathe under power finally. Nice to see it finally run. Unfortunately, there was a noise coming from the back of the headstock. I think I have tracked it down. The drive pulley that turns the input shaft into the headstock was loose. After taking off the belts and removing the pulley I found some issues. The retaining nut had backed off or was not tight enough, and this allowed the pulley to back off the tapered shaft and wobble around. Prolonged use like this damaged the taper in the pulley and the keyway. So looks like the fix is going to be to bore out the pulley bore. Then sleeve it and cut the taper in it. Then cut the keyway. So what do you think the best material is to use to sleeve it with? The pulley is cast iron. I was thinking bronze.
