POTD- PROJECT OF THE DAY: What Did You Make In Your Shop Today?
Having bought this metal tray about two, maybe even three years ago I decided it was high time it was put to its intended purpose.
Now my wife can have her cookie sheet back…though I doubt she’ll want it
@DavidR8
Very clean looking set-up you've got there.
Can you tell me where I can buy a tray like that? It looks unlike common bakeware that I'm familiar with.
Yesterday i got a suprasing call, i was removing the rear fog lamps from the scenic to refresh them and a friend of a friend call" i'm looking a for a car for my brother". My answer is you know me i don't sell my cars. He told me his price range, which was around a grand. Midway talking i looked at the scenic and ask him is he looking for a beauty queen or a workhorse. He said something to get around, to go to the river. So i told him get you brother and come to the big garage. They come looked at the scenic, we took it for a drive, run out of LPG, we had to fill it up. And they made me an offer which was good enough to move it along. This way i don't need to paint it, clean it anything. Today to get the title transferred i had to get it inspected and registered so it will be in my name to transfer it. So this morning took it to the inspection station it pass no issues even got a compliment, the guy there said the engine is soundless. Goat new licence plates on it transferred the title to his name, got paid. One less vehicle to work on, the guy is a bit older and doesn't seem to know to drive too much. Thankfully i installed a new OEM clutch, so if anybody see it coming give him some space. :grin big:
IMG_20220601_155151lllllll.jpgIMG_20220601_154659.jpgIMG_20220601_154941llllllllllll.jpgIMG_20220601_154657.jpg
POTD was working on my 20-year old Delta miter saw. This particular model (36-255L) has line lasers on either side of the 12” blade to mark the cut. It works great, until it doesn’t. . . My wife went to cross cut a board; the saw worked, but the lasers didn’t.
Our Delta 12" miter saw with the handle off for "fixing"
Pulled the handle and put 3.7 V directly to the lasers and they fired up. Checked the output of the 110 V to 3V transformer and got nothing. Went on Amazon and got an 80 – 230 V to 3 – 20V LED driver for $7 delivered. Wired it in and fired up the saw; no lasers. Went back to the direct 3.7 V battery check and no lasers, what the heck?!? I checked the output of the LED driver at 50+ V DC; cooked the lasers. . . Stupid me, I should have checked the output voltage before firing up the saw. I’ll have to check on the difference (?) between an LED driver and a transformer. The LED driver label says it’s constant current, so voltage must be varied to maintain a constant Watt output? My electrical no-how pretty much stops at E=I*R and P=I*E.
3.7V battery fired up the lasers fine
50+ V from the new LED driver (ouch)! The lasers expect a max of ~5V.
Google’d replacement parts for the saw and found the laser modules for about $93 each (ouch). Pulled the lasers from their mounts and measured them at 10 mm diameter. Searched on Amazon for “Laser line LED” and found a ton for under $10. But the diameters were all 6, 9 or 12 mm. Ordered a couple of 9 mm ones. I didn’t show it, but ended up using a 110V to 5V USB plug-in transformer for the power source.
The original lasers have a hex on the end for adjusting the clocking of the laser line (clock the line parallel to the saw blade). This was added by drilling out a couple of ¼” nuts which were glued to the lasers with red Loctite. I went the quick route to build up the diameter from 9 mm to 10 mm by running some electrical tape around the lasers. Not my best fix, but I have a plan B. I found some 10 mm x 0.2 mm wall stock brass tubing on Amazon which will be here in a couple of days. The lasers press into a plastic detail, they are easy to pull. I'll Loctite a length of tubing in place for a more solid fix. The tape works fine, but I’m worried about plastic creep over time which could lead to misalignment.
1/4" - 20 nuts chucked up prior to drilling them out with a 9mm drill
Checking fit with a laser
Original lasers up top, taped up replacements below.
Mounting brackets for the lasers. The lasers press into a plastic detail. A screw on the side adjusts the position side to side. The hex nut on the back of the laser is used for clocking the laser line parallel to the blade. The headless set screw is used to flex the plastic mount side to side to adjust the laser so it's parallel to the plane of the saw blade.
All wired up and caulked (gasket goop) at the top. I didn't show it, but I misrouted the jumper harness from the saw handle to the lasers. The routing is important; the saw blade clipped both lines . . . I'm pretty good at soldering wires back together . . .
Back in business!
I adjusted the lasers by flushing a piece of white cardboard to the blade, then taped it in place. Then adjusted the clocking to be parallel with the blade/paper edge. Then adjusted the beam to be in the same plane as the blade with the headless set screw. Lastly, adjusted the side to side screw so the laser is scrubbing past the side of the blade to mark the kerf.
Thanks for looking, Bruce
Great write up Bruce!
Arbor press arrived… but I could not leave it blue….
Took it apart… deburred the handwheel and polished it. Painted the center black.
Also had to file down sharp edges around the handle area in the casting. They were too sharp to grab by there…
Now I can move it around by grabbing it there…
Rod was rough cut but easily fixed in the lathe…
Then some hammered green paint on the rest and now it matches the rest of my tools… installed the Vevor sticker back on it so nobody confuses it for anything but what it is…
There are a few improvements I want to make to it… other brands have a gib for the front of the ram…behind the front cover. This one has none, the bolts go directly against the ram. I will make a gib out of Delrin…not sure it needs to be made out of steel.
And then I want to make some brass inserts for the side adjustments… again, so bolts do not go directly into the side of the ram…
