POTD- PROJECT OF THE DAY: What Did You Make In Your Shop Today?
Pretty much finished. Need to put some scrap steel roofing oil it and call it done.
Of course had to try it out, eats the small stuff, but the blade only comes about 2 - 2 1/2 inch above the table, so still need to deal with the heavy slabs.
Greg
POTD was improving the watering bucket for our (soon to be harvested) meat chickens. My wife made the watering can a few years ago; 5-gallon bucket with 5/16” holes drilled, tapped with a 1/8”-27 pipe tap, then screwed in what’s called a “chicken watering cup”. It works pretty well, the cups have a yellow spring-loaded plug that when bumped by a beak lets water run into the cup. The problem with her setup is the 5-gallon bucket is only about 1/8” thick; not a lot of thread engagement for the cups. The meat chickens put on a lot of weight in a hurry, little chick to an 9-pound bird in 6-10 weeks. When they get up in size, the clumsy oafs step on the cups and knock them loose. If they knock one completely out, there goes 4+ gallons of water into their pen.
POTD was to make some aluminum reinforcing nuts to shore up the cups. I used 1” aluminum; faced, center drilled, tap drilled, tapped, tapered the lead edge, knurled and parted. I used a couple of 3/8” washers to shim between the nut and bucket as I was afraid of torqueing too hard and snapping the plastic thread on the watering cups.
Works really well, the cups are very stable. Next step is whacking the herd. Oh, in case you are a member of the ASPCA and are concerned about the tight proximity of the birds, don’t worry. The first batch we raised years ago were allowed to free range. If you’ve ever had meat chickens, you can stop laughing at me now. All meat chickens want is water and food. When we let them free range, they never got more than 2 feet from the food and water. The smallest bird we’ve harvested had two breasts that weighed 15 oz. each. The largest, 1 lb. 15 oz. for each breast. We average over 5+ lbs. of meat per bird, you’re looking at well over 250 lbs. of chicken meat in the pen picture. My wife has the process down pretty well; I do the whacking, she does the skinning and parting out. Guess what's gonna be for dinner!
Thanks for looking, Bruce
Chicken watering cup; yellow detail is spring-loaded. Bump it and water trickles into the red cup
Faced
Used a center drill to spot. The tip of center drills are usually 120 deg. making them ideal for spotting 118 deg. drill bits
tap drill
Tapping a 1/8" - 27 pipe thread
checking the thread
Chamfering the surface. The thread is tapered, I'll know to start this end of the nut
knurled
parted
Ready for install
The nuts really helped stabilize the watering cups.
Gotta keep 'em hydrated
POTD was GREAT; it was me watching a crew of guys do the work in 95 F weather! We recently had solar panels installed by Pink Energy. They still have a little work to do, but the system is somewhat up and running. Trenching for the buried electrical lines is still open pending inspection. Also, we need the power company to come and bless the system before we potentially start sending power back up the grid.
Our array has 22 panels that put out up to 380 W each (>8 kW/hr. output)
Irony. The guy cutting the extra off the horizontal supports had his battery die. . . Part of the wrap-up is dressing the ends of the horizontals
Back view of the panels. The electrical hook ups are covered by stainless steel hardware cloth. The sales gal told us that a horse got behind the panels and touched hot/ground.
Specifics on the panels
Battery back-up power in the basement. We have 3 cells that provide 9 kW/hours of power
Control box is at the shop. Our electric meter is at the shop. Our main panel at the shop has a buried line to the house. The control box has to be at the main panel for sending power back up the grid.
Trench with DC and AC lines running to the house (battery back up and power to the house)
come on guys keep things on HM going.. I'm bored.. at my sons house watching my granddaughter, I need something to read and look at when she's not in my posession...more projects..:teacher::pickaxe::chemist::digger:
Oh man, what a joy it is to use the right tools… threading this was such a breeze…
Of course I need to get a new bolt because I bent the heck out of this one with previous tries and wrong tools… but now I know that the next one, with this handle and die, will come out correctly.
And just for kicks, took it to the buffing wheel to see how hard it would be to make it look better…and this will clean and look great in just a few hours…
Only took the die and center part of the holder to the buffing wheel…. Quick pass since I had family coming over… will finish it over the weekend…
And just for kicks, took it to the buffer to see how hard it would be to make it look better…and this will clean and look great in just a few hours…
Only took the die and center part of the holder to the buffer wheel…. Quick pass since I had family coming over… will finish it over the weekend…
don't let the wire hit the dies. it will damage them. Those are high carbon steel I think. if you have a air die grinder, put a scotch bright pad on the dies if you want to clean them, it won't get into the threading section... it will just work on the face.
Looks nice. BTW, that's not a big handle :grin:
Got it… This was just using the buffing wheel (cloth).
Look, it is the largest die handle that I now have in my toolbox, okay!? :grin big::grin big:
My project this evening. My son still plays baseball. Apparently the summer wood bat league has no restrictions on bats. We will see.
