POTD- PROJECT OF THE DAY: What Did You Make In Your Shop Today?
Another bucket emptied on the garage floor . Pic to come . Lots of good lathe tools etc . in there . What I'm planning .......take them down the basement and arrange everything together that goes together , then sell the piles as lots . This next bucket will be a nut buster ! :eek: Making progress slowly but surely . Oh , and scrap some stuff out , not burying anything any more ! :grin:
Couple ( 1000 ) more drills and reamers to add to the basement pile . I'm starting to hate buckets . :eek:
I have to clean my shop like this. I can barely walk in there right now.
well, I finished my powerfeed install with the final piece of the puzzle.
My table lock didn't quite fit anymore.
I toyed with making a regular handle fatter on the end then the middle like the original. But opted for the type I put on my quill lock.
Overall, I'm happy with it. I wish the bluing came out blacker, like the original, but it looks good with the constrast, at least my opinion.
Again a small project round the homestead. My mower was getting very noisy when I engaged the blades, so I dropped the deck to take a look. I checked the spindles which were quiet when spinning. I had rebuilt all 3 of them a few years back and they were still fine. I found the noise in the belt tensioner idler wheel. I proceeded to find one locally and online and there were so many variations it got ridiculous.
I did find a bearing but the pulley was two halves spot welded together to hold the bearing. So I took it to the lathe and carefully cut off the part that holds the bearing on one side to get it out. I did not want to drill the spotwelds and have to try to get the two halves to run true again. I recessed the bearing hole in the pulley a little deeper to make up for the material I had cut away on the other side. I then installed the bearing and carefully welded the retainer back on. It was a case of spot weld a little, let it cool, and repeat so as not to cook the new bearing seal. After the welding was done I chucked it back up in the lathe to smooth out my embarrassing looking welds.
As is my norm, I have no before or during shots, but here is shot of the completed project. All in all it cost me a bearing and a little time and it was completed in a mornings work/play. I wonder what the rest of the world does when stuff breaks and you can't get replacement parts easy.
Made another couples of organizers for my mill tooling, though realized afterwards that I'd forgotten holes for some boring bars :)IMG_20220606_161809.jpg and today, instead of sitting through tooling for people like I said I would, a friend came round with a set of drums off a Fairlane 500 (Torino) that needed cleaning up. Too big for my SB9 by far and almost too big for my mill. Got to use my new boring head with a 3/4" solid carbide bar. Took a while but they came out ok and my friend was happy!IMG_20220611_133412.jpgIMG_20220611_150425.jpg
Before dinner I hopped downstairs and decided to create a bunch of arbors for my collets.
when I made the handle for the table lock in #6666 above, I took a drop, drilled /threaded it for 10-32 so I could hold the part in my collet while machining it. I have made a bunch of these over the years and just toss em when done. well b4 dinner I said enough of that. I realized just put another size on the other end so I put 10-24, then I grabbed another small drop and made 8-32 and 6-32.. next time I'm in the shop I'll make 1/4 -20, 5/16-18 and 3/8-16.. I'll make a block of wood to put them in so I don't keep making the same thing over and over.
should have done this long ago.
