well no, a mister is not really recommended. I had flood coolant running, but it was a disaster., I made my own aluminum pan to collect things. But I could not find a suitable drain so I machined one.. it did not work, I then created a T bar out of copper for air to enter, it was better, but not great, The coolant was overloading the drain. dialing it back was not working.
So I went the mist route, which is how I was doing things before the flood coolant.I was using a spray bottle. There is a big difference between finish when dry grinding and wet grinding. Wet is much finer. I believe because it keeps it cooler, and lubes it. I could use wax on the wheels, but I am doing the mist. When I find copper or brass plate at a reasonable price, I will remake the pan and solder in a big drain. I'll make a sub pan for the drain to drain into with another drain, that way the drain hose is not moving back and forth.
Yea I use Kool mist 77.
