I guess at this pount this has become somewhat of a journal.
After last nights post and this morning before work i did more test on the column and head. Overall the test were good. Im finding my magnetic indicator holder could be playing a factor. Im also finding my nod to be a heck of a lot less. Makes me winder if the gib wasnt seated properly.
After cleaning everything up and getting it back together its definitely running a lot more smoothly. For right now i have the gibs tight but im not sure its neccessary. Probably going to do ankther 40 test lol then see if i can get the spindle to table within acceptability. Fingers crossed, i could use some hope right about now. Glad i got some.
I think im realizing there's multiple factors with a machine like this when trying to achieve decent repeatability as well as smooth operation(how it feel manually) and function, aside from how nice and tight of a fit the dovetail/gib matches up. B2 you were right about the gib not being a clamping force. I learned much about that. Is it acceptable to put loctite on gibs? Not really confident enough in my adjustment but i could see it being helpful. Maybe a washer could have same effect in my situation
NEVER LOCTITE!
You will want to adjust it in the future. The proper way to do this is to loosen the screw at the gib small end. Then tighten from the big end until you get it where you want it. Then tigthen the small end back up. The gib is then held in the proper position by the clamping of the screws pinching the ends of the gib towards each other. Hence my need for the washer with the finger sticking into the gib hole. Not pinching toward the ways as is happens when the little end of the gib gets chewed off. The way surface of the gib is scraped (certain amount of roughness) to leave grooves for it to hold oil. This tends to prevent as much wear on the ways. At least that is the theory. I also realize that for flat surfaces only 3 points actually make contact at a time, unless one of the surfaces bends. Think legs on a table. After operation these points tend to wear down and become more flat to give more surface area of contact. If the points are really high then the gib may need to be retigthened a bit.
In my bad gib case, I removed the gib and laid a 0.005" shim along the non-way side to take up the space. This moved the gib ends up where the top screw could be adjusted. I then added the washer with the finger to the bottom screw to hold the gib from moving up and down in the saddle.
The taper on my gib thickness is about 0.0088"/inch. This means that a shim of 0.005 will cause the gib to be about 0.005/0.0088 ~0.57" higher. I measure the taper directly from the bad gib as well as down the gib hole. So for a shim I actually used a piece of Al tape which had adhesive on one side. I put the adhesive against the gib (non-moving way) side. So the Al was then toward the saddle clamps. Not ideal as the clamps would cut right through it to the gib material, but I do not use these screw clamps anyway.
So the gib is working until I made another and the mill works. I have made a lot of thing, but many of them were before I realized I had such a bad gib! My real issue is that the column ways spacing variation.
My z-axis nodding is still about 0.001 to 0.0015. I am sure I could make it smaller by tightening the gib, but then I would be concerned about the gib tightness when the head travels all the way up to the top of the Z-axis. Fortunately, I seldom do that either.
Dave
