- Apr 21, 2015
- 682
I'll chime in since my gage pins are one of the most used tools in my shop. I use them CONSTANTLY for all sorts of stuff (far more than simply measuring holes). They are incredibly useful for setup work. I prefer to use them over gage blocks whenever reasonable (no chance of screwing up the stack accidentally -- just grab the size you need).
As far as what sizes you'll want: as silly and obvious as it sounds, it's worth pointing out that you can put TWO pins in a hole to gage a diameter. (I went an embarrassingly long time before I realized this!) A set of pins up to 0.5000" let's you trivially gage holes up to 0.9990". Add a single 1.0000" pin (or a carefully mic'ed dowel) and you can measure up to 1.5000" (anything bigger and telescoping gages are accurate enough).
The most common use for my pins are positioning parts and fixtures relative to a stop. I also seem to chuck them up in lathe chuck or Jacobs chuck in the mill fairly often to position things off the spindle axis (oh: it's also incredibly useful to know the exact diameter of your mill spindle for the same reason!). They are particularly handy when boring holes on the lathe to a critical depth with a carriage stop. Just face a hair off the part with the boring bar (or just gently touch the face), then position the stop with an appropriately sized pin between the stop and the carriage.
Note that pins give you a good tactile check for any taper in a bore, too.
As far as sizes, I've got two "minus" sets (which is what you want to measure bores): one set from 0.0610" to 0.2500", another set from 0.2510" to 0.5000", and a single 1.0000" pin. That's been perfect for my needs. Anything smaller that 1/16" and I'll use feeler gages and shim stock. Anything larger and I'll use telescoping gages, gage blocks, adjustable parallels, or whatever.
I don't remember where I bought mine (probably Enco or MSC) but they were pretty cheap and my experience was similar (all were about one or two tenths under the marked sizes (as well as I can measure). They were a LOT cheaper than gage blocks. I'd rather have an expensive micrometer I trust and a cheap set of pins than vice versa (for my hobbyist shop).
