As far as wrist pins go, I have plenty of those. I’m an Automotive technician and a professional engine builder. Just never thought about using a wrist pin till you mentioned itI use my .061" - .250" set and my .251" - .500" set about equally. I use them for more purposes than to check hole diameters so having the complete range is useful for me. The smaller set is less expensive so maybe the first one to buy. I would like to add the .501" - .750" set but the cost is significantly higher. I had written in a previous post about combining three pins to measure over range holes which gets me by. https://www.hobby-machinist.com/thr...o-extend-measurement-range.96790/#post-903491
As mentioned above, when I am measuring runout, I usually use wrist pins. They are dictated by their use to have a tight diameter and straightness tolerance. A local small engine shop, marina, or implement dealer would be a good source.
