The
Bob Smith Adhesives website has a feature that lets you ask questions, so I did. I described my project and asked which of their products they would suggest. I haven't heard from them, but if they have a suggestion I'll probably order some.
In the meantime, I've ordered some Loctite 638; should be here Saturday. I settled on 638 by using the
"Looking for a product?" feature on Henkel's website.
My selection process was:
Product Category = Retaining Compounds
Substrates 1 = Metal: Steel
Substrates 2 = Metal: Steel
Brand: LOCTITE (this was an irrelevant choice because by then all the choices are Loctite products, but what the heck, might as well)
Physical Form: Liquid
Cure Type: I ignored this choice because it wasn't going to affect the outcome at that point.
Key Characteristics: Ignored this one also, because I was already down to two choices.
Applications: For Slip Fitted Parts
Color: Who cares? Just ignore this. Actually, I'd pay double for any Loctite product that comes in polka dots.
That process led me to 620 and 638. So I selected both products for "Add To Comparison" (you can compare up to 4 products), then I hit "Compare 2/4". That took me to a side-by-side comparison of 620 vs. 638. Here's where I picked 638 over 620.
The two products seemed very similar. The fixture times are 620 = 60 mins vs. 638 = 4 mins. I don't care about that. The other big difference is shear strength, which I don't care about either because the only force being applied (when I use the gizmo I'm making) amounts to pushing the gage pin
into the blind hole. Even the Gap Fill rating is the same... 0.15mm to 0.25mm. I don't know why "Gap Filling" is mentioned in 620's characteristics but not in 638's characteristics. They're both retaining products, and they're both for slip fits. The 620 product is for high temperature applications, but that doesn't seem to be relevant.
In the end, I assumed either one was going to work just fine. I let a coin flip decide for me.
I think I just don't know much about machining and I like to figure out how to do things in a manner that is as well-thought out as I can. Seems to be the way I'm wired. Sorry if I seem like a strange guy to you all!
