- Aug 21, 2023
- 105
My favorite spray gun is a DeVilbiss FinishLine FLG HVLP they cost just under $200.00 and have several tip sizes. That’s a High Volume Low Pressure with the paint container on top. It uses low air line pressure and sprays more paint. Getting far less over spray. You’ll need to take more care as runs are easier for being inexperience.
First off make sure the enamel is NOT water base! Use oil base only. Practice with mixing a thinner I use Xylene and start off with 25% thinner to paint ratio. I suggest that you mix an automotive hardner at the recommended ratio adding at last moment in a mixing cup. Then pour into the guns cup. The hardener will give the paint far more durability. You’d be amazed. Also filter the mix when pouring into gun.
Test the ratios to see what works best. Along with the gun’s pressure and pattern settings. Keep things constant. spray patterns and distance from nozzle to work.
Keep the area clean make a make shift area using plastic curtains. Wear a good respirator with a full face mask and painter body suite and gloves. Even when you’re mixing. This stuff is very harmful to your health.
I’m lucky enough to have a full size paint booth at home that makes for better end results.
With a little trial and errors you’ll be surprised at your results. Good luck and keep us posted how you make out.
