- Jan 4, 2021
- 3,096
Leave it long and mount it in vise standing up . You could use an end mill to plunge , or use a boring head for the radiis . Not sure what tooling you have on hand .
That was my thinking, but waiting for more experienced folks first. With my LMS 3990 Mini-Mill, table to spindle nose is 13-1/2, including 2" Riser Block, less 1-7/8" table to bottom of vise (plus 7/8" tall jaws). My 1/2" Boring head sticks out 3", and my 1-3/8" cut bar sticks out at least 3/4". Even without the Riser Block, my boring head would work, assuming @ssdesigner leaves an extra 1" to grab in the chuck.
However, due to the lack of rigidity of a Mini-Mill, I would go with 1" & 1/2" end mills, making the 1/2" radius cut first to have the most material backing up the cut. I would also make multiple plunges for both radii, gradually eating away at the stock (I made 7/8" radius cuts in a 9/16" thick 6061 fluted knob and 3/16" radius, 2-1/8" deep relief cuts for SHCS's this way – took a little time, but came out perfectly). The radii may not be as accurate using the end mills as could be achieved with a boring head on a larger machine, but with a Mini-Mill it's a toss-up. Also, even with the multiple passes with the end mills, it will still take less time than with a boring head.
I used 4-flute end mills.
