New G0602 Setup
Off topic but IMO, the forum is definitely worth supporting. I waited for several months before becoming a supporter, the first year with $10 and ever since with a $25 donation. With over 43K registered users (as of 2022), if everyone were to contribute, it would greatly enhance the operating budget of the forum.
Edit: I realize that some of our members are retired and/or on fixed incomes. I am one of them. But a $10/yr contribution is less than the cost of a meal at a fast food joint or a couple of drill bits or an end mill.
I just ignore the requests for bank account linkage.
In my opinion, this forum is worth supporting. I've received a whole lot of knowledge and help from here. So I try to help others here with what I've learned and experienced, to pass it along.
As to pay pal I did that and the limited my account to the point of un-usability so no longer using it. I would love to support this sight, does anyone know of another way to pay than PayPal?
Maybe we can create a new thread on this? Don't want to dilute this one. In the off-topic area I would imagine, as it is not really machining related.
i'm redesigning my compound and looked at his but am concerned that instead of pulling the base of the compound slide down onto a solid surface it clamps the round column that the compound base is attached to, i just think that is more places to flex where when the base of the compound slide is pulled down you have a larger footprint so longer moments to increase rigidity.
Any thoughts on this?
This is the type project where I would like to have a surface grinder, set up and grind the 2 mating surfaced truly flat. I have read a lot about guys having issues with rigidity and it makes me wonder if some of the issues have more to do with the machining of the mating surfaces.... :confused:
I used a card.
Had to redo the tool rest side plate thread for the QCTP bolt with proper tools since the hand threaded one described earlier wasn’t square.
Got a new one from Grizzly and set it up in the 4 jaw chuck to drill and tap square. Hand turned the chuck to make the thread.
Now square
Want to give a shout to to Grizzly's excellent service. I sent them an E-mail with a picture of the belt bits all over the pulleys on the drive side, they sent a pair of US made replacement belts in a few days
Came up with a cheap way to enable locking down the belt tensioner from the gear side.
Drill out one side of the adjuster leg to 3/8”
Get a 1/2” T-slot nut, run a 3/8x16 tap through it, and turn down the inside shoulder to match the adjuster slot radius at each end
Now you can use a 3/8” x 16 bolt through the adjuster leg into the T-slot nut placed from the back side
Tighten/loosen from the gear side to adjust belt tension
Paul, that’s an excellent fix for the adjustment. That’s the second worst feature of the G0602 and G9972Z. I’ve pondered it a few times but never put effort into a fix. I have a long 17mm combination wrench that helps but it’s still not even close to your solution.
