New G0602 Setup
I had a chance to install and test a Grizzly T10721 milling attachment on the lathe.
I used an MT4/ER32 collet adapter to mill at 2,400 RPM spindle speed. Easily removed 0.015" per pass at 0.250" cut length, neither the mill or part got hot. Very smooth, no chattering at all.
I made up a pair of clamps to mount an LMS 3769 2" screwless vice to the milling attachment slide, easy to mount square using a pair of drilled and tapped holes at either end of the slide. Cut depth on the test piece was the same on both sides, confirming square setup.
